Silhoute curve with 30 degree
Hi…,
is there an easy way to create a kind of silhoute curve under 30 degree. Please see this picture:
http://www.flexicad.com/service/forum/index.php/topic,8408.msg13392.html#msg13392
Thanks
Michael
www.flexiCAD.com
Hi Michael- No, and yes… that is, No, but there is a test command, (unsupported, use at your own risk, etc. and does not autocomplete and is not really ready for ‘prime time’) TestSilhouette. This command accepts a draft angle input. Set the view to the desired ‘pull’ direction. Surfaces should have their direction (normal) facing the camera if possible…
