SilhouetteLines in Concept Display Mode with THICK lines
Hi all
Is it possible to get much thicker SilhouetteLines in Rhino 9 as shown in this illustration?
I would like them to be visible in the Concept and Monochrome DisplayMode and also be included in the CaptureToFile, where I have tested the result in varying resolutions with no luck so far :slight_smile:
I have also experimented with the different options available in Options > Advanced -also no luck.
Hej Tim -
The setting for this is the "Silhouette line width (pixels) setting in the display mode settings under [...] > Objects > Lines. This is currently capped at 10 px.
That issue is on the list as RH-29403 DisplayMode Edge Thickness Does not Print
Fantastic. I can use that setting for now, but would prefer to have an external silhouette-line separate from the internal silhouette-line. The effect is to strong IMO if you have many internal apertures like:
Followup question: Is there a setting where you can choose to have or not to have the new soft grid?
