Is silhouette not creating only the visible lines?
Seems to include all lines projected from one view.
Thank you for clarification, need to export a 2D DWG for a floor plan.
Make2D - my bad
The Make2D dialog box should have a ‘Hidden Lines’ checkbox that you can switch off.
@Oscar3dm thank you
Hi Hannes -
For something like that, you could also use the MeshOutline
command.
@wim thank you. Yes it did outline all lines in different scenarios.
