i was trying to install Rhino 6 via the offline package (bootstrapper.exe). I used the following command line:
bootstrapper.exe -package -quiet -norestart LICENSE_METHOD=STANDALONE LICENSE_KEY=%myevalkey% SEND_STATISTICS=0 ENABLE_AUTOMATIC_UPDATES=0 DISABLE_INTERNET_ACCESS=1
Getting always an exit code of -2147024894.
Digging in the underlaying msi and trying a install of these with the properties results in a 1603 error.
The msi log shows me a problem with the license custom action:
MSI (s) (BC!20) [09:37:35:384]: Product: Rhino 6 – ERROR: RMA_SERIALNUMBER is a required property in CA ‘InstallLicense’.
This is a deferred custom action
Set the property ‘INSTALLLICENSE’ to
“RMA_SERIALNUMBER=;OTHERPROP=;…”
CustomAction InstallLicense returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
A manual install is working. But i need the silent way to rollout the software on several systems.
Windows 10 1709
rhino_en-us_6.16.19190.07001.exe
Corporate Proxy & Firewall
How can i solve the problem? I do only need Rhino 6 for viewing purposes.
Best regards,
DK
