Siemens NX, Catia, Solid Works, ICEM Surf,Alias or Rhino or ...?
Siemens NX, Catia, Solid Works, ICEM Surf or Rhino?
hi I’m not an engineer. I want to model and 3D print (people said non‑CADs don’t give a good quality surface), but I found that engineering software is also very good. Maybe later I wanted to do it seriously. I am not focused on a specific thing. I want a versatile and vast software but good for 3D print (real world) and capable of big detailed things.
I want to model things like
spaceships, cars, robots, buildings (Zaha Hadid type), facades, organic things, normal objects, human body and face, animals, node-based modeling… (everything)
pls answer detailed and updated if you have time and consider plugins. and if there is another software, please say. thanks
You’re really overthinking this - most of the software you named offer trial versions, download it and have a play, look at the pricing, which can you afford? (Dassault software costs like £3-7K a year, if you’re not an engineer and just looking to get into 3D Modelling, then it seems kind of obvious, you don’t need either solidworks or catia?)
Also, you need to adjust your perspective imo - instead of looking for people to tell you you what to think; read and make up your own mind - it’s your life, so live it. Why ask people to write “detailed” answers about things you can learn yourself with a quick google search?
Frankly though, it sounds like you need blender - it’s free, it’s powerful
… pretty wide selection!
With mechanical objects like cars you can manage with almost all the softwares you mentioned.
But modeling “organic things”, human body and face, animals… almost none.
With Rhino maybe you can manage. But even Rhino is not suited to do “organic art” efficiently… it just happens to be the least-worse of the ones you mentioned.
Also, what about licensing?
You mention so expensive softwares like is no problem getting all of them? :sweat_smile:
What is your context? Hobby?
Rhino can be yours for 1000-ish bucks and then it’s your forever. Others have a yearly cost.
Rhino doesn’t really excels at anything, for any specific context you can find another software that is better, but it can do only that.
Rhino, instead, is “really good” at almost any context, a swiss army knife, it has node-base modeling (Grasshopper)…
(Anyway, if you use Rhino correctly, it can also be better than any other software in many fields)
Instead of pirating a software, consider buying Rhino or go with Blender.
With Blender you can create everything you said, as art (not really accurate, but enough for 3d print)… and it’s free.
At face value the answer is Rhino. Regardless of what program you choose you need to put in the time. Some of the stuff you want to do will require extensive Grasshopper expertise and A LOT of hours. For programs like Rhino and Blender, the biggest “expense” is the amount of time you spend mastering the program, so be sure of want you really want to do before investing serious time. Rhino includes a 90 day free trial which helps out a lot.
Being that your description is both a little broad and vague - nothing wrong with that when you’re just getting going, but be warned that it affects the quality of advice you’ll receive. Some programs for example can model a suspension component on a car AND do FEM analysis on it. For body panels, Catia can achieve a “class 1 surface”, but it comes at a steep price. Rhino will model the ENTIRE car the fastest and at a bargain.
