i’ve got a single curve used as shut line which is applied to a relatively coarse mesh (6348 Faces). When i change the layer of this curve or change the visibility using _Hide / _Show, the shutlining is re-computed which takes some time. I think this is a bug. As long a the curve does not change, no recomputation is required.
btw. no re-computation happens when i turn the layer of the ShutLine On/Off. This is good.
Hi Clement, I think I know what you are pointing out here but in V7, at the moment at least, I cannot get those messages to appear on the command line… still poking.
