Shut down Rhino
Hello all, would it be possible to implement a shut down button in the interface ?
Sometimes Grasshopper or Rhino bugs for some reason and we just want to shut it down.
The current process right now when a bug appears is to completely shut down Revit and restart it, quite impractical.
Thank you
Totally understand the issue, especially on a large Revit project which can take time to open/save.
The reality is Rhino is running inside the Revit memory space, if you open task manager you only see the Revit instance. To close Rhino once it’s started inside Revit you will need to close Revit.
If there is a repeatable issue with a particular workflow please let us know and we can address it.
Okay, impossible to do. Got it.
