As I am working on a training exercise for Shrinkwrap functionality, I miss some feedback functionality in the pop-up dialog.
In the marine industry, many people receive STEP files from suppliers to fill up an engine room with many components for example. As these Rhino files then explode in size, they have to optimize the file-size of individual components with shrinkwrap.
The challenge is then to find a balance to display quality (attractiveness/recognizability) and the amount of vertices in the mesh result. This is always relative to the original geometry, regardless whether that is Step (nurbs) or mesh input.
In a spreadsheet, as a baseline, I set the amount of vertices of “ExtractRenderMesh” on 100%.
Then I compare that with the results of several Shrinkwrap qualities in which the parameters "Target Edge Length"and “Polygon Optimization” are most important variables. Only this way, I can find a balance.
In the pop-up dialogue I miss feedback of the amount of vertices of the preview result. It would even be nicer when there is also a display of the ExtractRenderMesh amount of polygons. In the image above, you can see my idea. Is this feasable?
