Shrinkwrap function
I expected “ShrinkWrap” follow the external shape of target, but generated mesh is inside of the target mesh partically. Can I wrap target mesh all?
use a smaller target edge length value untill the preview of your mesh is acceptable
Thank you for answer. But I don’t want to increase the number of polygon…
Gotta have more polygons to get more detail… it’s just the way it goes with polygons.
you can crank up the optimization value in shrinkwrap and it will add more polys in the higher curvature areas and decimate flatter areas so you can get more detail with less polys. Or you can mesh it high poly and decimate with the reduce mesh command.
I want not detailed shape but shape that wraps all target shape, as if vaccum forming. Thank you for advice.
