ShrinkTrimmedSrf can be used without exploding the polysrf and it’s not a bad idea if you don’t intend to Untrim anything later. You can also at times use Explode > RebuildEdges > Join to fix small issues in a joined edge but I’m not sure what the actual issue you are trying to solve is.
