ShowMultiListBox() bug
Hi, there seems to be a bug with Dialogs.ShowMultiListBox() for RH6.
The dialog never pops, while if i use ShowListBox() instead with the same parameters it works.
I will use another control instead so I dont really need it right now, but you might want to fix this.
Hi @Matthieu_from_NAVINN,
What SR of Rhino 6 are you using?
@Trav, can you look into this?
– Dale
@dale @Matthieu_from_NAVINN
It should be working in 6.6. I redid many of the ETO based dialogs last week and fixed several things MultiListBox was one of them.
I just did a quick test on a debug build and it appears to work via rhino script and rhinocommon.
14761478
import Rhino as r
a = [ ‘one’, ‘two’, ‘three’ ]
rscriptresult = rs.MultiListBox(a,“Script Message”,“Script Title”,“one”)
print rscriptresult
rcommonresult = r.UI.Dialogs.ShowMultiListBox(“UI Dialog Title”,“UI Dilaog Message”,a)
print rcommonresult
I am currently using Rhino SR 6.4. I’ll download the latest RC but it seems the 6.6 is not out yet
That’s correct. SR4 is final and you can subscribe to Release Candidates for SR5. If you need to test something now on a “daily” for SR6, we can provide you a link.
