ShowDir has two bugs in the current V9 WIP.
Work In Progress(9.0.26160.12305, 2026-06-09)
- The Flip Direction, Reverse U, Reverse V and Swap UV buttons only function with a specific sequence of clicks. This was reported by @Rhino_Bulgaria in Rhino urgently needs these tools!
ShowDir
Select an object or objects.
The “Direction Analysis” panel opens and the direction indicators appear on the selected objects as expected.
The buttons do not function.
Click somewhere else, not on a selected object.
Click on a selected object.
The buttons now function (but not always).
Add an object using the panel icons.
File with sample objects: ShowDir sample surfaces DC01.3dm (182.3 KB)
- The command line is left with “Select objects to remove direction display” after closing ShowDir.
ShowDiractive with the Direction Analysis panel displayed.
NO objects selected (shown in yellow)
Click on the “+” panel icon to add an object BUT do not select an object
Click on the “-” panel icon to remove an object BUT do not select an object
The command line shows “Select objects to remove direction display”
Close the Direction Analysis panel.
“Select objects to remove direction display” remains on the command line even though the panel is closed.
The only way I’ve found to clear the command line:
Select an object.
Command line now displays: “Select objects to remove direction display. Press Enter when done”
Enter
Command line now displays: “Select objects for direction display”
Enter
Command line is now clear.
