Zoom Window Command, will show “Unknown or unimplemented command”, but these command still can work after click Cancel or OK.
Zoom works fine from command line & my Alias Z. Also with Zoom window icon works here on new file.
Are you typing Zoom Window? Like that, with a space?
I see this. In the application menu, select View > Zoom > Zoom Window.
Rhino for Windows gets the same error, it just ignores it. Oh, @pascal …
Hmm- that is the menu macro- with too much input - Zoom all by itself is ‘Zoom Window’ , the ‘Window’ part is not needed in the macro at all, it looks like. I will buggify this, probably a Mikko fix - thanks.
http://mcneel.myjetbrains.com/youtrack/issue/RH-28021
type “’_zoom” is OK, on the menu has problem, will show “Unknown or unimplemented command”.
