Is there a way to show and hide the Safe frame by code?
Thanks,
Rafa
@maxsoder - can you help with this?
@rafadelmolino Do you want to do it in C# or Cpp?
Hi!
C#.
Thanks,
Rafa
At the moment the C# API is not public. I will check out and see what we can do to make it public. I will write back when I have more information.
Regards, Max
I have created a YT issue about this and assigned it to me. https://mcneel.myjetbrains.com/youtrack/issue/RH-65788
I will make it public in Rhino 7.x branch which currently is v7.12.
Best Regards,
Max
Thank you!
Rafa
I have now implemented this. The Rhino.Render.SafeFrame will be available in Rhino v7.12.
Br,Max
