Show options without using layer
Hi all,
I have been using layer to show different design options but always think that there must be a better way to do it. Using layers will increase number of layers and mess up the model and you will need to do extra works to tidy up layers later on…
So I think there must be a clever way to show options. For example, use a grasshopper slider to switch on and off groups of objects’ visibility. But how can we control objects’ visibility? I don’t want to hide / unhide object manually because all those options are on the same location and you always pick a wrong group of objects…
Thanks for any suggestion,
Jack
Looks like this just appeared… Maybe exactly what you need. --Mitch
Thanks Mitch! I will get WIP and give a try~
