Show mesh vertex directions?
Hi…,
my Rhino customer has problems with the mesh vertex directions (in other 3D programs).
How to show all vertex directions of a mesh?
Thanks
Michael
www.flexiCAD.com
Hi Michael,
in Rhino you can show the vertex normals with the _Dir command.
But that’s probably too easy…
Jess
Hi Jess,
_Dir shows only some and not the different directions at the same vertex:
See here: https://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/weld.htm
Thanks
Michael
If you _Unweld you’ll see the individual face normals at that vertex.
But sometimes Rhino seems to skip vertices to avoid cluttered display.
If this is the case, then you can _Explode the un-welded mesh to get all normals displayed.
Good work-around, but I don’t want to explode or unweld the mesh. I just want to see all directions in the joined welded mesh. :slight_smile:
I knew that it was too easy :wink:
Then you need a script.
If anyone has something ready I could do it later…
Yes, too easy :wink: Please don’t write a script. This is more a wish for an improved _Dir command or an additional display option.
I will help myself now to show this my custom in blender:
@Michael_Meyer, @Jess - testMeshDir will show both vertex and face normals.
Hi Pascal,
great, this is what I want.
Thank you very much and a nice weekend
Michael
P.S.: Wish: Options should keep the last setting.
