Show/hide all 3 axes with/without grid?
Hello.
The z-axes seems to be controlled per viewport (wireframe, shaded, etc) (…why?..) and it stays visible even when ShowGridAxes is off, unless grid is hidden, then it also hides z-axes. The command line grid command doesn’t expose the x-axes toggle.
So, we can have a toggle hotkey -_Grid _ShowGridAxes _Enter (or Gridaxes) to show/hide all 3 axes while grid is hidden and only x/y-axes when grid is shown.
How do we show and hide all 3 axes lines with a hotkey, regardless if grid is on or off?
Thank you
Hi Vano,
I recently added a feature request for more control.
This python script toggles the XY axes and also modifies the active view’s display mode to show/hide the Z axis as well.
#! python 3
import Rhino
def toggle_three_axes():
	grid_axes_state = rs.ShowGridAxes()
	new_state = not grid_axes_state
	rs.ShowGridAxes(show = new_state)
	display_mode_id = rs.ViewDisplayMode(return_name = False)
	display_mode = Rhino.Display.DisplayModeDescription.GetDisplayMode(display_mode_id)
	display_mode.DisplayAttributes.ViewSpecificAttributes.DrawZAxis = new_state
	Rhino.Display.DisplayModeDescription.UpdateDisplayMode(display_mode)
toggle_three_axes()
@Measure thank you for the script. It works, but it doesn’t update other viewports, so hidden axes in one viewport might show z-axes in another.
This version updates all viewports (it does current viewport first and updates others in separate thread for speed)
import Rhino
import threading
	current_mode_id = rs.ViewDisplayMode(return_name = False)
	# Update current viewport's display mode immediately
	current_mode = Rhino.Display.DisplayModeDescription.GetDisplayMode(current_mode_id)
	current_mode.DisplayAttributes.ViewSpecificAttributes.DrawZAxis = new_state
	Rhino.Display.DisplayModeDescription.UpdateDisplayMode(current_mode)
	# Update all other display modes in the background
	def update_others():
		for display_mode in Rhino.Display.DisplayModeDescription.GetDisplayModes():
			if display_mode.Id != current_mode_id:
	t = threading.Thread(target=update_others)
	t.daemon = True
	t.start()
toggle_three_axes()
I think it’s a bug. It has to do with the settings shown below. Z axis goes away when you change that option back and forth.
These work for my macros, but I had to add a return key after it and z axis remains.
_NoEcho _Grid _ShowGridAxes=No
_NoEcho _Grid _ShowGridAxes=Yes
