Show gumball on selected objects
Anyone knows how to show the Rhino gumball after select the objects by code like that:
RhinoDoc.ActiveDoc.Objects.Select(objIdList, true);
Thanks and regards!
Will
Have you checked this example?
Thanks but this example is for a custom gumball, I would like to select and object by code and show up the Rhino Gumball.
Regards
Hi @Harper,
You might just want to script the Gumball command.
– Dale
Thanks @Dale, it’s a good workaround!
@dale
Is there a way to do this in RhinoCommon yet?
My idea is that I want to save the chosen mode first before changing it so that I can revert it, once my command is finished.
To script the Gumball command? Sorry, not sure what’s being asked.
– Dale
hi @dale,
sorry, I will be more specific.
Acutally I already put my question here:
In short:
The scripted version I understand that’s fine of course.
But, let’s say what if I wanted to create multiple gumballs, attached to multiple elements.
Of course now that I read this with a bit of distance it sounds quite hard to achieve.
But maybe there’s a way.
If not, the scripted variant will do of course.
Thanks,
T.
