Whenever I select a curve I want the curve length to be shown at mouse pointer like dialog box.
Rhino has all the information available “under the hood” - it would be great to have an “Information Window/Control Panel/Object Lister” like in Alias that permanently shows/hides anything relevant you’d like to know about selected CPs, curves, and surfaces, also to make fundamental changes, like changing a curve’s or surface’s degree/spans on the fly.
Basically a great idea. Because one would like the info boxes to be relatively small I can imagine it would be quite a project to come up with the list of appropriate most important things for each type of object. It should also be an option the user can turn on and off. I can imagine that it could become quite annoying if it popped up for every selected option. Also: how would it deal with multiple selections?
