Premise: shout/hear component are fantastic.
I particularly love how it also works inside of clusters.
I have found a few discrepancies in how/if they operate, plus would be wonderful to have a couple extra functionalities.
Discrepancy 1: some components can listen to the shout if name is given as variable, other just don’t appear to be receiving it
Discrepancy 2: somehow, if an input is connected after the expression is set to a shout variable, the input is ignored. I would expect the wired data to have priority, or at the very list a problem or alert to be displayed. Instead, the variable in the expression “just” takes priority.
Wish: often times, a variable is used in multiple points across the definition. Instead of creating a slider, naming it for navigation and documentation, creating a shout component, naming it accordingly (but also as duplicate), then connecting individual listen blocks, why not give an option to a slider (maybe other inputs as well?) to just broadcast their value? Seems like a simple & clean enough implementation, reducing redundant interactions and streamlining components communication.
