Should these results be identical?
When using cross reference for a list of branches or a specific single branch I get different results for one branch out of over 865 branches all other branches output the data as expected. Branch 777 shows unexpected geometry for the B output. When I isolate the branch I get the expected geometry.
Based on this image, should the cross-reference B output not be the same for both scenarios?
I cannot figure out what I may be doing wrong. Any suggestions?
grasshopper issue.gh (309.8 KB)
much easier to demonstrate with numbers :slight_smile:
grasshopper issue_re.gh (197.6 KB)
you’re making the wrong assumption about cross reference
try this
now the two branches are equal
*from your original script
*if you want to stick with b branch
