I noticed that I can get different results when extruding a surface depending on the curve direction. To me this doesn’t make sense. This is how the method is supposed to work according to the help file:
The low-level extrusion function does take the curve direction into account. If it didn’t, you’d need to provide additional input to help the function figure out the correct direction. Probably easier to just orient the curve.
