Shortcuts within commands?
This is a minor request, but would it be possible to implement Aliases while other commands are running?
The example I’m currently running into is this – I run the Trim command, and then, to trim multiple lines, I use the SelBrush tool. I can type in “selbrush” and the command runs, but when I type “SB” (My alias for SelBrush) it does not work.
Not urgent, would just be a convenience thing! Thanks!
That should work actually - it does here.
Is your alias sb simply _SelBrush ?
Yes. Works outside of commands, but not when another command is running.
Hello - That does work here.
Huh - working for me now too. Not sure what the issue was.
