Is there a possibility for a shortcut/macro for match hatchpattern - similiar to MatchProperties?
It’s a bit akward to always having to use the Match button for this - whereas most of everything else works with (fast) shortcuts.
Thanks.
Thanks.
Hi - we have a wish for including hatch properties in the MatchProperties
command and I’m adding your request to that item - RH-27591.
Until that gets implemented, from the thread in that report, it looks like @Holo has a script to do that that he might be able to share.
Yeah, my hatchmatch is a lifesaver.
So send me a PM if you are willing to report how it handles in your use.
It is made for my use, but there might be limitations that I didn’t think of.
It matches layer, color, hatch type, scale, origin and orientation.
Hi Holo
Where can I find that script? Thanks.
I’ll PM you the script
Perfect, thanks.
Any Way to add this to a Macro/ Shortcut?
Hi - what Jørgen sent you was written to be put on a button:
-_RunPythonScript (
### --- HatchMatch by Holo
[snip]
HatchMatch()
To make an alias or keyboard shortcut, you have to extract the python script from this and save that to a file on your PC - e.g. HatchMatch.py
You get the python script by deleting
-_RunPythonScript (
at the top and the
at the end of that code.
Finally assign
! _-RunPythonScript “Full path to wherever you save the py file, in double quotes\HatchMatch.py”
to your alias or keyboard shortcut.
On second thought, to make it easier I just put it here:
HatchMatch.py (905 Bytes)
Thanks for the script Holo, we’ve been needing this in our shop for a long time.
Eric
Works well.
Only thing I can’t get working with this script is if printcolor = display. Does ObjectPrintColor not take display as an arg?
color=rs.ObjectColor(obj2)
colorsource=rs.ObjectColorSource(obj2)
printcolor=rs.ObjectPrintColor(obj2)
rs.ObjectColor(obj1, color)
rs.ObjectColorSource(obj1, colorsource)
rs.ObjectPrintColor(obj1, printcolor)
Hm… I might have to add a printcolor type thing. I’ll look into it.
Dear Holo
Your precious script isn’t working anymore in the latest Rhino 6, 6.18.19266.14201
Is there any way to resolve this? Thanks.
