I was able to project my desired show base onto a curve.
I extruded it into a surface as shown.
However, I can’t seem to make it into a solid.
If anyone has any tips it would be greatly appreciated!
Thank you!
Thank you!
send your file?
You are awesome! Youtube is my savior but its sometimes hard to pin point which exact video to watch and you end up going down a completely different rabbit hole! This helped a lot! I just did it the old fashioned way with the split command by adding surfaces on the top and bottom manually.
