Hi all,
Working on my mesh again, I got an issue:
When generating all the triangles, the last row would get duplicated, making the final join operation impossible.
I hunted the issue down to this list of booleans (red), the purpose of which is to dispatch (yellow) all the concentric rings of points between the rings which have the same amount of points (blue arrow) and those in which the amount of points doubles (green arrow). the issue seems to be that the boolean list goes [0,1,…,n], but the triangles creation uses the elements [0,1,…,n-1] and the elements [1,2,…,n], thus the boolean list was too long and seemed to create an extra row of points, creating an extra row of triangles on the outer rank (I hope my explanation makes sense)
So I though that simply using two sublist elements to create the [0,…,n-1] and [1,…,n] lists would fix the issue: well, it does fix it for the blue arrow section, but for the green arrow part the triangles don’t generate anymore.
and now I am a bit stuck.
Thank you in advance for your help
0227_IBO_mesh-log-grasshopper.gh (32.5 KB)
