Shell Polysrf in 2 distances
Hello!
I need a polysrf to be shelled in 2 different distances. I dont like offsetting polysrfs since it may give odd results…
i dont know how to explain my problem :sneezing_face: so im uploading an image with the specifications i need, marked in red. pls see below…
please feel free to post any comment!
thanks
You can use shell then press Ctrl + Shift and move the inner surface
example
not sure i understand, i guess you could shell once. then explode the result and shell with the inner surface of the shell once more. if that is not what you want, maybe try a little harder by explaining with a better sketch or elaborate the problem a bit more.
Hi! @encephalon & @vikthor sorry for bad explanation… let me upload a more specific image…
here you have…
box is made op of 2 polysrfs… i need the same for hull
you can try this you need a reference plane.
scale_.gh (14.6 KB)
Hi @vikthor!!! there are 2 observations… first: the sideview of your boat hull has non uniform shell thickness and that might a problem for me since i have to model the interior of the yacht…
second: i dont know how to use GH… Those GH parameters or input values look complex… :dizzy_face:
@vikthor Im simply looking for a tutorial for dummies :stuck_out_tongue:, i dont want to bother you or anyone else with difficult tasks… anyways ill download your file model for examination. Always a pleasure and thanks for your reply…
you just need to upload the file to the designated component equals the values and get what you want.
and why not trying what i suggested? that will do ecactly that.
hi! mmm… not sure. my thoughts are that your sophisticated GH model only scales the polysrf (stylishly…) @vikthor, unnecessary complex your way of modeling, but professional. thanks anyway!
im not sure i understand @encephalon… could you please upload an image file. what you mean is to shell the original polysrf and then shell (again) the resultant polysrf?
