I hope you have solved such situations in Rhino 8 with the shell command.
With values less than 2 the command works. With values greater than or equal to 2 the command works partially, as it creates an open volume.
(the shelling should follow the logic of the “offset” command for the profile of the surface/face).
shell failed.3dm (180.7 KB)
Hello- please use DivideAlongCreases
> SplitAtTangents=Yes before shelling this object.
Thanks Pascal.
Works!
Maybe I’m talking stupidity: couldn’t the shell command work automatically? that is, without having to remember to divide the object on the folds (the command takes care of it).
In this case the shell command fails to empty the volume. Can you check please?
shell failed x.3dm (317.2 KB)
