Hi Rhino Community, I have created geometry (see image) using grasshopper which i have baked into rhino. I am trying to give the object a thickness, so that it is more realistic but the Shell command doesnt seem to work properly with my geometry, when i convert it to a mesh and then offset the mesh i also encounter problems… Does anybody have any tips on how to get either of these commands to work with my geometry? OR am I doing this the wrong way? Should i be using a different method altogether? I have attached the .3dm file if it helps.
Thanks In Advance!!!
vase.3dm (302.4 KB)
