Shell Command, Draft angle
Is there a possibility for the shell command to have a draft anngle and radius option
Is there a possibity for the ability to select and apply a draft angle to a surface
Alistair
Hi Alistair -
We have a request for that feature on our list as item RH-36110. I’ve added your request to that item.
It sounds like you could use the Rotate or Rotate3D command to do this.
Wim
I am sure if Rotate will do this But I will Try
Thanks
Alistair
Alistair Craig
79 Benagh Road
Kilkeel
Co Down
BT34 4SJ
Tel +44 (0)28 4176 5181
E: alistair.craig@sky.com
Wim Dekeyser
wim
McNeel
    March 26
Hi Alistair -
alistair.craig:
alistair.craig:
Wim
i have tried Rotate
Yes it is one way to go
But a single command line which extended the surface would be nice
rgds
Alistair
Alistair Craig
79 Benagh Road
Kilkeel
Co Down
BT34 4SJ
Wim
Thanks
Alistair
Alistair Craig
79 Benagh Road
Kilkeel
Co Down
BT34 4SJ
Wim Dekeyser
wim
McNeel
    March 26
Hi Alistair -
alistair.craig:
alistair.craig:
