SHELL: another problem
Perhaps I ask too much: the shell of the face with red border does not run properly. You could check? Or is it a case, at the time, with no solution?
Thanks.
Shelling problem 1.3dm (119.4 KB)
Hi Davide - my guess is the sheller does not the chamfer surface - if it is made like the one on the right:
Then shelling works… I’ll add this to the pile…
http://mcneel.myjetbrains.com/youtrack/issue/RH-33724
thanks,
Thanks Pascal :wink:
