Good Day, I had a large amount of intersection points using MCX. CLX and CCX doesnt work. My issue is how to gain the index parameters to split at. When i shatter the curve, it doesn’t shatter at intersection point.
Note that: all lines are not horizontally straight. I cant sort it based on height, Y
You will need to provide a list of shatter parameters for each line. The wires going in to the shatter component show that you are just providing two lists.
The inputs to your MCX components are flattened, which is suspicious, but without the file it’s difficult to say for sure.
