I’ve drawn some line to represent dimension lines. However you and barely see them.
How can I control the line weight so it’s more visible in ShapeDiver?
I’ve done some work on the lines using Shapediver materails. this helps but I still have no control over line weight
Line weight is not currently supported but we plan to add this feature in the new version of the viewer. As a workaround, you can model lines as flat meshes which would give you control over the width.
Thanks. It works well now.
