I have three groups of graphics I want to display synchronized. Even I set the three groups to absolute position, they are displayed separately.
hI,
It would be a lot simpler if you uploaded the file!
thanks for the the valuable remark.
If you want to display multiple shapes on top of each other, you have to feed them into the same “shapes” component. It can be useful to take advantage of trees + longest list to match up your styles to your objects, like so:
StackedShapes.gh (18.4 KB)
Thank you.
Actually if I apply this to my case it slows down so everything so much that the whole solution become useless…
Then you’re probably doing something wrong! As @anikolo said, it’s much easier to help you if you post a file.
I am trying, i am trying… but somehow I am struggling with internalize data. Right now it does not work for me.
This example shows a create-and-update pattern - you can see that even with hundreds of shapes added/ changed it performs in near real-time.
StackedShapes.gh (26.4 KB)
Thank you. It works perfectly!!!
