Hey
I would like to achieve a reflective floor in shapediver, something like the effect in the following image.
I tried adding a surface of my own and changing the material but it would only reflect the environment and not the object made in grasshopper.
I thought of a workaround of actually mirroring the object itself and then somehow fading it with a translucent floor surface… Any other ideas?
For performance reasons, the ShapeDiver viewer does not perform ray tracing for computations; what you want to achieve is therefore not possible at the moment.
It could be possible to add a simple raytracing or even some other trick to achieve the specific ground floor effect you are looking for. Our team will evaluate this request and I will update this topic when we make progress.
