ShapeDiver font modification - UX-UI problems
Hi ShapeDiver Team,
I am writing to inquire about a change I noticed a few days ago on the platform, which is affecting all the applications we have running with ShapeDiver.
Both in StarModul, Ifitec, and Noxifer, we have observed a change in fonts and sizes that disrupt the display on the web apps.
  • Is there any possibility of reverting to the previous configuration?
  • How can we prevent platform changes on ShapeDiver from affecting the applications we have already delivered in the future?
The main issue we are facing is that these apps required a significant amount of time to ensure everything was visually aligned, and now, suddenly, clients are experiencing numerous display issues.
  1. As an example, I am attaching an image of Noxifer before the change:
  2. After the font and size changes:
The same issue occurs with Ifitec, where, in this case, there is also a jump in the tables:
Best regards
We released a performance optimization for the 3D text tags recently, which seems to cause the issues you are seeing. We are working on a fix and I will let you know once it is deployed.
Hi Mathieu, do you have any update about this?
The problem has now been fixed. Please test and let me know if you find any remaining issues.
