I have a problem with email exporting. I added all parameters for email export component and it works locally ( i can export locally). However, when I upload grasshoppper definition and click on export i receive following message: Sorry, there is no data to be exported for these parameter settings.
What might be the problem?
I am uploading to sdeuc1 (Rhino 6, shared Geometry Backend). I am developing my model in Rhino 6. Also I noted in the meanwhile that export works specifically for the Weaverbird component wbThicken that I am using to get 3d model thickness for 3d print. If I use another geometry to export it works…
If you share a link to your model with me, I can check its computation log for component warnings or errors. In the next release, this information will become visible in the computation logs.
