Shapediver error visualization lines
Hi, I’m having problems with the visualization of lines in one project,
I need to solve it quickly because is an online tool that is been presented in the next days.
It was working fine when i uploaded but now i found an error:
I have this parameters and works fine
Then i switch a toggle and the lines dissapear , this wasnt happening before
If I switch back the toggle (comming back to the originals parameters), the problem of the line visualization persist. Showing that is not a problem with the parameters.
Thanks for your help
Can you create a minimal definition (maybe starting from your own definition and removing unnecessary components) and post it here so I can debug your issue? I don’t have enough information to help based on your screenshots.
Hi Mathieu thanks for your quick answer
I developed a minimal definition with the same issue in the platform.
I transfer you the model in the platform but just in case you still need the gh file i will send you in private.
Thank you for your report. We have identified a bug with the display of lines that will be fixed in the next viewer release, I will let you know when it is available on the platform.
