Manuel2
(Manuel Amicone )
June 1, 2023, 12:59pm
1
Hi @mathieu1 , I’m having problems when I try to edit the name of the parameters in the platform. It seems like is working, but when I press “save” the changes in parameters names are not working. It is courious because if I go back to “edit” the model the names are OK.
Thanks for your help!
mathieu1
(Mathieu Huard)
June 5, 2023, 6:14am
2
We could reproduce the bug and are working on a fix for the next release, I will get back to you when it is done.
Manuel2
(Manuel Amicone )
June 26, 2023, 12:27pm
3
Hi @mathieu1 , any news about this topic ?
Thanks
mathieu1
(Mathieu Huard)
June 26, 2023, 12:58pm
4
This issue is already fixed in our development environment. It will ship with the next platform release, which will happen within the next two weeks.
Manuel2
(Manuel Amicone )
September 18, 2023, 2:39pm
5
Hi @mathieu1 , do you have any news about this ?
Still having the problem
mathieu1
(Mathieu Huard)
September 19, 2023, 5:23am
6
The issue has been fixed in one of our last releases, I just tested and everything works as expected on my side. Please link a model and describe which parameters and names are causing issues.
Manuel2
(Manuel Amicone )
September 19, 2023, 7:06pm
7
Hi Mathieu, yes, the issue is solved in the platform, but when i paste the Iframe to a web, the parameter rename is not done. Look this image:
I changed the name of this parameter in the platform, then obtain the Iframe and when i look to my web the name is the old one.
In advance, thanks for your help.
mathieu1
(Mathieu Huard)
September 25, 2023, 7:19am
8
The issue still exists in the iframe, it will be solved in the next platform release (around mid-october).
mathieu1
(Mathieu Huard)
October 16, 2023, 6:04pm
9
A fix for this issue has been released earlier today. Please test and let me know if it is resolved on your side.
