I have a surface and I need to cut a central round piece from it. It looks okey in my file, but when I upload it to shapediver, the full surface shows, and not just the central piece (I selected it as list item).
Can someone help me please?
prova_tondo_08.gh (17.0 KB)
I could reproduce the issue and we will investigate it. In the meanwhile, a workaround is for you to mesh the Trimmed Surface before sending it to the display component (using the “Mesh Brep” component for example). I just tested this solution and it works fine on my side. It is anyways good practice to manually mesh the geometry you send for display in the online viewer.
