The ShapeDiver Component “3dm Export Options” won’t accept “8” as a Rhino 3dm File Version Number.
Perhaps it defaults to 8, but this explit exclusion raises an eyebrow.
ShapeDiver Version 1.29.1
@ ShapeDiver developers: Please fix this.
You can only export to Rhino 8 if you are working in Rhino 8. Can you confirm which version of Rhino is throwing this error?
I tried reproducing this using Rhino 8 SR 24 (the latest service release), ShapeDiver 1.29.1, but it works as expected. It looks as if Rhino is loading the ShapeDiver package for Rhino 7 instead of Rhino 8. This would also explain the other issue you are experiencing (loading error on .NET Core).
Somehow I believe Rh8 was indeed loading a package for RH7, although I couldn’t locate one.
Deinstalling and re-installing ShapeDiver cleared up the issue on my machine.
This route cause is probably the same as in this post.
Both can be considered closed topics.
Great, many thanks for your feedback. Sorry for the inconvenience. We have been seeing several issues with the package manager lately.
