Shapediver app error, ParamRef/ParamWidget)
I can’t find the error in my script. Help would be appreciated. I’ve simplified the script as much as possible.
TT_versie1-1b7_test.gh (106.3 KB)
In grasshopper when I change “height2” to 3465 the viewer changes ok
In Shapediver when I change “height2” to 2980 the viewer changes ok
In the Shapediver app when i change “height2” to 1111, although it says it is changing “height2”, it changes the height of opening 1 in the viewer and in the text widget. Any changes to opening 3 are also not applied to opening 3, but to opening1
here is the link to the app
It seems that a bug was introduced in the latest version of the App Builder. We are working on a fix, but in the meanwhile you can go back to version 1.0.15 in the App Builder by replacing the latest part of the URL with 1.0.15:
https://www.shapediver.com/app/builder/v1/main/1.0.15/?slug=YOURSLUG
It should solve the problem for now. I will update this topic once we release of fix for this issue and you can switch back to the latest version.
The issue is now fixed, you can dismiss the message above and use the latest version of App Builder again.
