Hello everybody. It is possible to make a shape for array of objects in grasshopper?
Categorized.
Please assign your new messages to the appropriate category so the right people see it.
Thanks
Excuse me. This is my first question here. Iâll try to figure it out.
Yes.
Thanks, Iâll try it.
What is not obvious from the image I posted is how Map Srf (Map to Surface) works depends on how the surface was constructed.
No worries.
Uncategorized message tend to be ignored.
same goes for categorized ones
Seems you want to treat your surface âdifferentlyâ,
if itâll continue to have four sides;
hence why not make it an EdgeSurface and go from there:
Shield2.gh (10.5 KB)
@Joseph_Oster would have preferred to help you without plugins anyway
Especially when they have no Grasshopper file/geometry attached.
I did.
As I understand this solution works for a shape with four edges. If there are more edges?
Isocurves are the key to Map To Surface, regardless of how many edges. As you can see from the animated .gif I posted, it doesnât work with Boundary surface.
Yes i see. And Isocurves can be only four pieces?
No⌠Isocurves are shaped by how a surface is constructed.
Boundary surfaces are âTrimmed Surfacesâ, their isocurves are determined by the underlying âUntrimmed Surfaceâ.
EdgeSrf produces âUntrimmed Surfacesâ where isocurves conform to surface edges. âUntrimmed Surfacesâ can be created other ways as well, such as Loft.
