Is there a plugin or some native solution to achieve the same functionality as Shape in Brep component but instead of Brep using Mesh? In this case Mesh would suit me better because I can have two disjoint closed volumes as an one Mesh where Brep is always just one closed polysurface.
I am sure there are a few methods, however it’d be better to look at the actual shapes/meshes you intend to use.
I say it because one method that comes to mind involves using the outlines of the containment meshes, which exist on a plane, then using the ‘center points’ of the shapes projected to the same plane:
SIM_example.gh (25.0 KB)
Maybe share your specific case study?
Best
