Shadows - No shadows in Rendered View - any guess why?
Would be nice to know if this is a bug.
thanks for any info! H
It probably is a limitation of your GPU but without a file and your display settings it’s hard to tell for sure.
Could also be an object really far from the rest of the objects.
If these are blocks that was made far from the origin then that could be the case as well. Try to select all and explodeblock and see if that works.
Or it can be a bad object.
It’s not the distance, rather: the fewer the polygon or item count the better the shadow
thanks guys for getting into this!
