I`am having problems with shadows in rhino 9 BETA. In OpenGL the faces of the object that are not lit receive light bleeding and are not all covered by the shadow. I am switching to the new Direct 3D option and the problem is gone which is great, but the shadow is covering the edges and the shadow intensity % slider is not making the shadow transparent so i can see the edges.
Well in the open gl one it has some artifacts where the shadow is not covering the entire face(the red markings in the screenshot), the direct 3d fixes that issue but the shadow is opaque, blocking the edges of the object. In Direct3D, even if i dial down the shadow intensity, the shadow remains opaque and my edges are not showing like in the opengl one. Direct3d produces the correct self shadows of the objects, but does not support transparency so that the edges are visible. Maybe it is not fully developed in the Direct3D so that the shadows can be transparent like in the opengl mode, or maybe it is something on my pc s behalf. I have uploaded the file and the system info. Thank you.
