Hi All,
Is there a technique to create shadow outlines in a faster way as I need to compute it for 1000s of objects.
Function has to be similar to "Shadow study component of Ladybug.
Regards,
Porus
Hi All,
Regards,
Porus
Some ladybug expert will help here also. But to get better results related to Ladybug visit here
https://discourse.ladybug.tools/
Cheers,
BVR
Hi Porusvakshoor,
you could try it with the native GH-Component “Occlusion” http://grasshopperdocs.com/components/grasshoppermesh/occlusion.html
You will rather get regions as output ( curves ) than meshes.
But I think it should be faster than ladybug.
And I recommend you to mesh your breps once ( much faster ), this would speed up both variants.
greetings,
Bumaye
Thanks Bumaye,
Yes sure, I will definitely try that. Thanks a lot for your reply.
