Shadow setting
I couldn’t seem to get the shadow to change as I adjusted the time, I followed a tutorial but it doesnt seem to help, does anyone knows what may help?
On the right vertical icons, select the last one, the lightbulb.
Turn off “Sulight”.
Turn on “Sun”.
Hi! The setting is currently like so, but it somehow still stays the same.
In the Display Modes > Rendered settings page, what do you see under “Lighting method”? To me it looks like you may have it set to “Ambient occlusion”. If you want to have scene lights affecting it (including Sun), you must change it to “Scene lighting” (which should be default).
It worked! Thank you so much!
