Shadow problem
Hello! Last time i insert a fbx file in rhino, then in this file, all the modelisation are full of noise in all the modelisation in every view (shaded, rendered, artistic…etc). I try to reinstall the rhino, and it doesn’t work. But I can open it normally in some other computer (not all other computer). It shows the noise only in this file but not others).
Is there anyone can help me out ? Thanks a lot !
Move your model to the Origin at 0,0,0
also share systeminfo so we can help you
I moved my model to the origin and problem solved ! Thank you so much !
