Hi
My shaded viewport rotation looks like in wireframe mode.
and when I start to rotate the view:
Any suggestions whats the problem?
Hi
It’ll do that if it can’t maintain an adequate frame rate. Go to Options->View and under the “Dynamic Redraw” section reduce the Frames per Second to try to reduce it.
Default Frames per Second was 5, I reduced it to 2 and nothing changed.
Is your hardware acceleration working? What does SystemInfo say?
You can set the number to say 0.001. Then it will probably never degrade.
It looks like a graphic card driver problem, I just bought an eGPU and it’s drivers mess up the ones that are installed on the laptop. I can’t access Display Adapter Troubleshooter on a video card to check the Hardware Acceleration.
